I have not. The price is more than double the LX200V30 and the LX200V30 is more than adequate for any situations I have had to use them in. I would suggest that if you need more than a LX200V30 you should consider fiber.
Has someone connected two LX200V50? Iām having trouble with that ;( I cannot get communicaction with a twisted pair cable
Ok So We bought the LX200v30 and wanted to straight swap them as it looks like a straight swap aside from the physical width. Is it a straight swap? is the pinout different? if itās different has anyone got any information regarding the āupgradeā? The reason why we are doing it is to squeeze as much speed as we can down the umbilical as we are only get 27mbps. This will be down to the length of tether at 250m but want to keep it long and get a slight speed increase.
any help would be greatful.
Hi @Divertom80,
Iāve moved your post here because itās on the same topic.
From the discussions above Iād assume that itās a plug in replacement, but perhaps @rjehangir or @gwa-gwa could confirm. See Waltās response below.
Note Chrisās point about needing both ends to be using the LX200V30 to see any performance benefits.
The V30 is definitely not a straight swap. It has a totally different pinout and requires an additional power supply compared to the V20.
To use the LX200V30, youāll need their evaluation board, which is similar to the Fathom-X. You can find that here:
https://www.aliexpress.us/item/2251832651820336.html?gatewayAdapt=glo2usa4itemAdapt
It needs 12V input power I believe!
I agree with @rjehangir, The WisLink PLC LX200V30 evaluation board is the way to go. I have found that it is a lot quicker ordering directly from the RakWireless site. Here is the link to the product.
Input voltage is 6-24V.
I have a model to 3D Print for a standoff: Printables
I have attached documentation below:
WisPLC PRO Quick Start Guide (1).pdf (615.4 KB)
WISPLC_PRO_V30_PCB_20190410.pdf (590.0 KB)
WISPLC_PRO_V30_Schematic_20190410.pdf (92.2 KB)
Hi @gwa-gwa did you ever do a speed test of speed with the LX200V30?
Iām interested to know if itās better than the FathomX boards. We have two tethers, one 300m and one 150m, both are giving us max 30mbit/s at the moment.
Iām sure you know but iPerf3 is a more robust test than the built in blueOS bandwidth test.
I have not done a speed test in water. I think the results are very different when measuring speed when tether is on the spool versus fully deployed in salt water.
I switched over my interface cards to the V30ās and made up new topside boxes. I ditched the USB ethernet converters and did straight ethernet.
Here are my network speed results from a 300m tether.
Thatās a very impressive bandwidth. Good job.
Do you remember what speeds you were getting with fathomx on the same cable?
I was getting around 20 down and 30 up. Usable, but these V30s definitely help and the data stream has been a lot more stable.
I built a set for a client and he is very happy with his setup now.
We have been using LX200V20ās with no problem. To increase performance we are trying 2 LX200V30ās. These work soon after power up, then the main chip overheats ( >70 deg C on thermal imager) and transmission ceases - so we changed to th 2x LX200V50 EVBās I have and I had exactly the same problem, I get the problem whether i power up with 12V through the power socket, or with 5V through the micro usb ports. Any suggestions?
If it gets hot immediately, my initial thought is reverse polarity. But if you have it on a 5V USB, Iām not sure. Maybe try RAKās support?
I tested my polarity with a multimeter as I was hooking things up, just to be sure.
Thanks Kevin,
The power supply / voltage regulators are definitely not the problem - ass you havee noted, the problem occurs if I use the Rak 12V adaptor, or 5V via USB. It is definitely the Qualcomm chip that is overheating. I have started communication with Rak. My next step is to try a short length of cable instead of the umbilical, in a benchtop breadboard whith two PCās , the two LX200V30ās, and work my way up from there , to see if the heating is there even with the minimal setup, or if it arises at some informative point!
Hi connectionsā¦
Is lx200v20 and lx200v30 dev board have same transformer or different.
Hi @Rahulpan, welcome to the Blue Robotics forum ![]()
This is information youāll want to get from the product manufacturer. Have you tried looking at the technical specifications of the dev boards, or asking RAK Wireless if you canāt find the information you want there?
Yes, I have checked all the technical specs and attachments which is given by the RAK wireless but there is no info about this item for lx200v30.
I will try to ask RAK wireless.
Thanks for response.![]()
thanks for info. I found the solution in the RAK website ![]()
