Low light camera stop working
After bench test 5min, before dive. (Open dome)
Camera view meny collors before the camera shut off. Blueos can’t find the camera after this. Checked wiering and cabels, i tried to change usb port on raspberry without any difference.
Plugged camera into my computer and then the camera work, tried to switch it back to raspberry, but no camera detected. Fault code 502.
Blueis fw: 1.3.1. have tried newer one.
Is camera gone?
Hi @Fjosen -
It’s worth checking to see if the camera has been affected by technical bulletin 12.
Where did you observe the fault code 502?
Hi.
I observe the fault code on video page in blueos.
Hi @Fjosen -
That suggests the MavlinkCamera Manager process is having issues. Can you download and share your system logs here? You can find them in the bottom center of the left menu of BlueOS, at the gear icon (download system logs.)
Is your hardware using a Pi4/Navigator or a Pi3/Pixhawk?
