Hi guys,
Is there any way that we can connect our IP camera to blueOS?
Hi guys,
Hi @ugurdemirezen,
I believe that should be supported from the Video page in the latest beta image, but I’m not certain about what’s required to complete the setup, so I’ve asked internally and will get back to you ![]()
Following up on this, it’s apparently implemented as a test feature but is not yet stable or tested enough to have been set up properly/intuitively in UI. If you want to try it out, you can
We’re looking into whether it’s ready to be properly exposed in the normal Video page, but you’re welcome to do some testing in the meantime and report whether it works well for your application ![]()
