I use raspberry (raspbian 32 bits (armV7l)). I wanted to know if it is possible to build pingviewer on it. THANKS
Hi @sadeck, welcome to the forum ![]()
The advice given in this post is still current - it’s likely possible to build Ping Viewer on a Raspberry Pi if you want to, but it’s not a supported platform.
Is there a particular reason you want to do this / do you have an application in mind? It is quite unusual to use a Raspberry Pi as the topside computer.
Hello, thank you, the problem was with us rapberry. I changed it to 64-bit and followed the blue robotics instructios for builder pingiewer. It’s ok now
