Hi everybody,
I am writing to know if someone tried to use standard Pb gel 12 V battery with T200 motors and Basic esc.
Is it possible to use it? The voltage is lower for the max power peak but there are enough ampere for a great autonomy.
Hi Jacob I take a look to the T200 power curve in docs. At 12 volt the maximum power should be around 180W 3,5 kgf 15 Ampere of current apx. Can you confirm me the values?
