How to view (BlueOS) multi camera stream?
If I use QGC I’m able to switch between cameras. But unfortunately I’m not able to view picture in picture, therefore I’d like view 2nd camera feed in some other way.
Setup: Rasp4 + Navigator + 2 USB cameras, Latest BlueOS, video endpoints udp: 5600 & 5601
I was not able to open the network stream on VLC.
Can anyone suggest how I can view the camera stream in general using vlc?
Or recommend some other software for that?
Hi @mareks,
It’s best to use even numbers for video streams - programs like VLC will often assume things like 5601 is the audio for 5600. Try using 5600 for your main stream and 5602 for your secondary one :slight_smile:
Can you try creating a file “camera2.sdp” with the following contents:
c=IN IP4 127.0.0.1
m=video 5602 RTP/AVP 96
a=rtpmap:96 H264/90000
and then running that through VLC?
We’re planning to generate SDP files automatically in future (for the active streams), but have not yet finished implementing it.
There are some other receiving/playback options discussed here, but VLC should work, and is likely the simplest to set up.
You got 2 usb cameras working in QGC? I have been trying this with a deepwater exploration camera for tether management. I can only get the BlueROV Tilt camera to pass through. I do have the DWE camera on port 5601 though…I’ll change this to 5602 and see if it comes through…
Hi @FairweatherIT
There was a bug where we weren’t reporting the cameras correctly to QGC. would you mind trying BlueOS beta23?
Greetings William,
I installed the beta version from the BlueOS Repository and only “BETA” is listed. WHen I upgrade to this, it defaults to the rear camera (DWE) and does not allow me to choose the BR front camera.
Is there a place to find the BlueOS beta32 for direct download and “upload current file”?
Ian
