I am using a Raspberry Pi to interface with a Ping360 sensor and record data in a .bin log file format, similar to PingViewer. The Ping360 sensor is connected to my headless Raspberry Pi, and I aim to accomplish this using a Python script.
I have established communication with the Ping360 sensor using the ping-python libraries. The sensor is connected to the Raspberry Pi via serial communication, and I am using the following code to start the connection:
from brping.ping360 import Ping360
myPing = Ping360()
myPing.connect_serial("/dev/ttyUSB0", 115200)
message = myPing.get_device_data()
if message is not None:
print("Payload:")
print(f" - mode: {message['mode']}")
print(f" - gain_setting: {message['gain_setting']}")
print(f" - angle: {message['angle']}")
print(f" - transmit_duration: {message['transmit_duration']}")
print(f" - sample_period: {message['sample_period']}")
print(f" - transmit_frequency: {message['transmit_frequency']}")
print(f" - number_of_samples: {message['number_of_samples']}")
print(f" - data_length: {len(message['data'])}")
data_hex_strings = [f'0x{byte:02x}' for byte in message['data']]
print(f" - data: {data_hex_strings}")
However, I am unsure how to save sensor log data in a .bin file like PingViewer.
Can someone guide me on modifying my Python script to continuously store Ping360 sensor log data in a .bin file? I’d appreciate help with code modifications and additional steps. Your assistance would be invaluable in recording the sensor data for analysis.
this data decode from pingviewer gui
Decode message format
ID: 2300 - device_data
Header: start_1: 66 start_2: 82 payload_length: 1214 message_id: 2300 src_device_id: 2 dst_device_id: 0
Payload:
- mode: 1
- gain_setting: 0
- angle: 8
- transmit_duration: 11
- sample_period: 88
- transmit_frequency: 750
- number_of_samples: 1200
- data_length: 1200
- data: ['0x40', '0x91', '0xc3', '0xe6', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xf3', '0xec', '0xf3', '0xfb', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xf6', '0xf0', '0xe5', '0xe0', '0xde', '0xdc', '0xd8', '0xd6', '0xd7', '0xd0', '0xd5', '0xe0', '0xea', '0xf7', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xff', '0xfb', '0xf8', '0xf5', '0xf2', '0xed', '0xea', '0xe8', '0xe5', '0xe2', '0xe1', '0xe0', '0xdc', '0xd8', '0xd2', '0xcc', '0xc4', '0xc1', '0xc0', '0xc2', '0xc5', '0xc6', '0xc3', '0xbd', '0xb3', '0xa6', '0x9f', '0xa2', '0xa7', '0xac', '0xaf', '0xb0', '0xb4', '0xb7', '0xb9', '0xba', '0xb8', '0xb4', '0xad', '0xa7', '0xa4', '0x9f', '0x99', '0x89', '0x92', '0xa2', '0xb0', '0xbc', '0xc6', '0xca', '0xcb', '0xc6', '0xc4', '0xc3', '0xc4', '0xc5', '0xc3', '0xc3', '0xc2', '0xc5', '0xc8', '0xcb', '0xce', '0xce', '0xcd', '0xcb', '0xc8', '0xc1', '0xbc', '0xb6', '0xae', '0xa7', '0xa3', '0xa5', '0xa0', '0x8c', '0x85', '0x8f', '0x98', '0x9e', '0xa4', '0xac', '0xb6', '0xc0', '0xc7', '0xcd', '0xd1', '0xd0', '0xcd', '0xca', '0xc8', '0xc6', '0xc6', '0xc6', '0xc6', '0xc6', '0xc2', '0xbd', '0xb8', '0xb0', '0xa7', '0xa4', '0xa5', '0xac', '0xb3', '0xb7', '0xbb', '0xbf', '0xc2', '0xc3', '0xc4', '0xc4', '0xc3', '0xc0', '0xbf', '0xbe', '0xbd', '0xbf', '0xc2', '0xc4', '0xc6', '0xc9', '0xca', '0xc8', '0xc8', '0xc6', '0xc3', '0xbf', '0xbf', '0xc0', '0xc0', '0xc0', '0xc0', '0xbe', '0xb9', '0xb6', '0xb3', '0xb1', '0xb3', '0xb5', '0xb8', '0xbb', '0xbe', '0xbe', '0xba', '0xac', '0x9e', '0x9e', '0xa4', '0xa7', '0xa9', '0xa7', '0x9e', '0x96', '0x90', '0x8d', '0x86', '0x81', '0x86', '0x89', '0x91', '0x97', '0x9c', '0xa3', '0xa7', '0xa9', '0xac', '0xb1', '0xb5', '0xb8', '0xbb', '0xbc', '0xb8', '0xa7', '0x9a', '0x9c', '0x9d', '0x9d', '0x9d', '0x9c', '0x9f', '0xa5', '0xac', '0xb3', '0xb9', '0xbf', '0xc4', '0xc5', '0xc5', '0xc6', '0xc4', '0xc1', '0xc0', '0xbd', '0xbb', '0xb8', '0xb6', '0xb4', '0xb3', '0xb0', '0xac', '0xa4', '0xa2', '0xa5', '0xa8', '0xab', '0xab', '0xa8', '0xa4', '0x9f', '0x9e', '0x9d', '0x9c', '0x8f', '0x8a', '0x8d', '0x92', '0x93', '0x95', '0x93', '0x91', '0x92', '0x93', '0x93', '0x90', '0x8c', '0x90', '0x96', '0x9b', '0xa1', '0xa5', '0xa2', '0xa0', '0xa2', '0xa3', '0xa2', '0xa3', '0xa0', '0x9f', '0x9c', '0x99', '0x9b', '0x9d', '0xa0', '0xa5', '0xaa', '0xad', '0xaf', '0xaf', '0xad', '0xa5', '0x9c', '0x98', '0x92', '0x90', '0x8f', '0x8c', '0x8a', '0x90', '0x99', '0xa3', '0xab', '0xb1', '0xb7', '0xb8', '0xb9', '0xb8', '0xb5', '0xb1', '0xb0', '0xb0', '0xb1', '0xb3', '0xb4', '0xb4', '0xb1', '0xb0', '0xb0', '0xad', '0xa9', '0xa5', '0x9e', '0x98', '0x96', '0x94', '0x93', '0x95', '0x95', '0x95', '0x96', '0x94', '0x91', '0x8a', '0x8a', '0x91', '0x9b', '0xa6', '0xaf', '0xb4', '0xb8', '0xba', '0xb8', '0xb7', '0xb8', '0xba', '0xbe', '0xbf', '0xbf', '0xc0', '0xbe', '0xbc', '0xbc', '0xbb', '0xb9', '0xb9', '0xb6', '0xad', '0xa4', '0x97', '0x8e', '0x89', '0x83', '0x81', '0x81', '0x88', '0x8f', '0x98', '0xa1', '0xa6', '0xa8', '0xa9', '0xa9', '0xab', '0xae', '0xb0', '0xb5', '0xb9', '0xba', '0xbd', '0xbf', '0xbf', '0xbe', '0xbd', '0xb9', '0xb4', '0xb0', '0xac', '0xaa', '0xa9', '0xab', '0xae', '0xaf', '0xaf', '0xb0', '0xad', '0xab', '0xab', '0xa8', '0xa7', '0xa4', '0xa0', '0x96', '0x85', '0x86', '0x8e', '0x96', '0x9f', '0xa5', '0xa7', '0xa8', '0xa5', '0x9e', '0x95', '0x8a', '0x86', '0x89', '0x90', '0x99', '0xa0', '0xa6', '0xab', '0xae', '0xad', '0xac', '0xab', '0xa9', '0xa7', '0xa3', '0x9d', '0x97', '0x93', '0x95', '0x9a', '0xa0', '0xa6', '0xab', '0xac', '0xab', '0xa8', '0xa0', '0x97', '0x8f', '0x8b', '0x8f', '0x96', '0x9b', '0x9c', '0x9c', '0x98', '0x92', '0x8f', '0x8f', '0x8e', '0x91', '0x94', '0x96', '0x97', '0x99', '0x94', '0x8d', '0x7b', '0x75', '0x7b', '0x82', '0x89', '0x91', '0x99', '0x9e', '0xa1', '0xa2', '0xa0', '0x9f', '0x9c', '0x9b', '0x9a', '0x99', '0x98', '0x94', '0x8e', '0x8a', '0x80', '0x7d', '0x83', '0x8a', '0x91', '0x99', '0xa0', '0xa6', '0xaa', '0xad', '0xb0', '0xb2', '0xb0', '0xaf', '0xab', '0xa2', '0x98', '0x93', '0x93', '0x94', '0x95', '0x96', '0x96', '0x95', '0x97', '0x9b', '0x9d', '0xa3', '0xa7', '0xa7', '0xa7', '0xa6', '0xa3', '0xa3', '0xa3', '0xa4', '0xa5', '0xa4', '0xa2', '0x9d', '0x97', '0x92', '0x92', '0x93', '0x97', '0x9b', '0x9e', '0xa0', '0xa0', '0x9d', '0x99', '0x91', '0x8c', '0x8c', '0x8d', '0x92', '0x95', '0x96', '0x95', '0x90', '0x88', '0x7f', '0x7d', '0x7b', '0x7f', '0x87', '0x92', '0x9d', '0xa5', '0xaa', '0xaf', '0xb2', '0xb3', '0xb4', '0xb5', '0xb6', '0xb6', '0xb6', '0xb5', '0xb3', '0xae', '0xaa', '0xa5', '0xa0', '0x99', '0x93', '0x93', '0x98', '0x9e', '0xa3', '0xa7', '0xab', '0xad', '0xae', '0xaf', '0xb0', '0xb1', '0xb1', '0xb2', '0xb4', '0xb6', '0xb6', '0xb6', '0xb5', '0xb3', '0xad', '0xa5', '0x9f', '0x9f', '0xa0', '0xa0', '0xa3', '0xa2', '0xa1', '0xa1', '0x9f', '0x9b', '0x94', '0x8b', '0x89', '0x89', '0x8b', '0x8e', '0x90', '0x90', '0x90', '0x8f', '0x90', '0x92', '0x92', '0x93', '0x94', '0x93', '0x8f', '0x89', '0x7c', '0x70', '0x68', '0x66', '0x66', '0x6f', '0x76', '0x7d', '0x84', '0x8a', '0x8d', '0x90', '0x93', '0x98', '0x9e', '0xa1', '0xa4', '0xa5', '0xa5', '0xa4', '0xa4', '0xa3', '0xa0', '0x9d', '0x9a', '0x94', '0x8f', '0x89', '0x80', '0x76', '0x6d', '0x67', '0x5e', '0x5c', '0x61', '0x6a', '0x72', '0x78', '0x79', '0x7d', '0x82', '0x8a', '0x92', '0x96', '0x99', '0x9b', '0x98', '0x91', '0x8b', '0x7b', '0x75', '0x78', '0x7b', '0x81', '0x85', '0x88', '0x8a', '0x8b', '0x89', '0x8b', '0x8b', '0x8c', '0x8e', '0x91', '0x95', '0x96', '0x95', '0x95', '0x95', '0x93', '0x8f', '0x8b', '0x8b', '0x8c', '0x8f', '0x94', '0x99', '0x9a', '0x9e', '0xa3', '0xa5', '0xa7', '0xa8', '0xa9', '0xa6', '0xa3', '0x9d', '0x95', '0x90', '0x8d', '0x8d', '0x8e', '0x8d', '0x8e', '0x8d', '0x90', '0x94', '0x96', '0x9b', '0x9f', '0xa1', '0xa5', '0xa9', '0xa9', '0xaa', '0xac', '0xab', '0xaa', '0xa9', '0xa8', '0xa6', '0xa5', '0xa6', '0xa6', '0xa5', '0xa3', '0x9c', '0x93', '0x8d', '0x8b', '0x89', '0x8b', '0x8a', '0x8c', '0x90', '0x92', '0x92', '0x96', '0x99', '0x9b', '0x9d', '0x9d', '0x9a', '0x95', '0x8e', '0x8a', '0x88', '0x85', '0x82', '0x7e', '0x7f', '0x80', '0x80', '0x84', '0x87', '0x8a', '0x8c', '0x89', '0x86', '0x82', '0x84', '0x8b', '0x92', '0x99', '0xa0', '0xa5', '0xa7', '0xa6', '0xa5', '0xa4', '0x9f', '0x9a', '0x95', '0x8f', '0x8b', '0x8c', '0x8d', '0x90', '0x95', '0x96', '0x98', '0x9b', '0x9d', '0xa0', '0xa5', '0xa5', '0xa6', '0xa6', '0xa3', '0xa0', '0x9c', '0x95', '0x8a', '0x81', '0x80', '0x81', '0x85', '0x8a', '0x89', '0x87', '0x81', '0x78', '0x72', '0x70', '0x73', '0x73', '0x78', '0x7e', '0x85', '0x8a', '0x8f', '0x95', '0x97', '0x99', '0x9b', '0x9b', '0x9a', '0x9b', '0x9c', '0x9b', '0x9b', '0x99', '0x96', '0x93', '0x93', '0x94', '0x96', '0x98', '0x99', '0x98', '0x97', '0x96', '0x97', '0x96', '0x96', '0x95', '0x93', '0x92', '0x90', '0x8c', '0x8a', '0x84', '0x80', '0x7e', '0x7e', '0x82', '0x86', '0x89', '0x8b', '0x8d', '0x8f', '0x8e', '0x8e', '0x8f', '0x8e', '0x8e', '0x8f', '0x90', '0x8f', '0x88', '0x84', '0x7a', '0x7b', '0x79', '0x79', '0x79', '0x73', '0x75', '0x74', '0x79', '0x82', '0x8b', '0x91', '0x96', '0x99', '0x97', '0x95', '0x92', '0x92', '0x92', '0x93', '0x95', '0x95', '0x95', '0x97', '0x98', '0x97', '0x99', '0x9a', '0x98', '0x99', '0x9a', '0x98', '0x99', '0x99', '0x98', '0x98', '0x96', '0x97', '0x97', '0x96', '0x94', '0x94', '0x95', '0x98', '0x99', '0x9c', '0x9e', '0x9d', '0x9b', '0x9b', '0x9c', '0x9c', '0x9d', '0x9e', '0x9d', '0x9d', '0x9b', '0x99', '0x99', '0x99', '0x97', '0x92', '0x83', '0x7c', '0x7e', '0x87', '0x90', '0x95', '0x9b', '0x9d', '0x9c', '0x98', '0x93', '0x8b', '0x86', '0x88', '0x8b', '0x8e', '0x92', '0x96', '0x98', '0x9b', '0x9e', '0x9f', '0x9f', '0x9e', '0x9a', '0x8c', '0x84', '0x88', '0x8e', '0x92', '0x97', '0x9a', '0x99', '0x9a', '0x99', '0x95', '0x90', '0x8b', '0x87', '0x87', '0x8c', '0x90', '0x94', '0x97', '0x96', '0x91', '0x8b', '0x84', '0x7d', '0x7d', '0x7d', '0x83', '0x87', '0x89', '0x8b', '0x8d', '0x8f', '0x8f', '0x8f', '0x8f', '0x8e', '0x8d', '0x8d', '0x8a', '0x89', '0x88', '0x84', '0x7e', '0x75', '0x6b', '0x5f', '0x60', '0x69', '0x72', '0x79', '0x82', '0x89', '0x8e', '0x93', '0x96', '0x95', '0x93', '0x8e', '0x87', '0x83', '0x7e', '0x80', '0x80', '0x7d', '0x76', '0x68', '0x64', '0x62', '0x68', '0x6f', '0x75', '0x7d', '0x83', '0x85', '0x86', '0x84', '0x80', '0x75', '0x69', '0x69', '0x6e', '0x75', '0x7b', '0x81', '0x88', '0x8c', '0x8f', '0x90', '0x8e', '0x87', '0x82', '0x7b', '0x78', '0x77', '0x76', '0x78', '0x79', '0x7a', '0x7b', '0x7c', '0x7f', '0x82', '0x83', '0x85', '0x87', '0x88', '0x8a', '0x8c', '0x8c', '0x8b', '0x88', '0x7f', '0x73', '0x74', '0x7a', '0x80', '0x84', '0x87', '0x86', '0x7f', '0x73', '0x6a', '0x65', '0x68', '0x67', '0x64', '0x61', '0x5b', '0x5d', '0x5c', '0x5e', '0x67', '0x73', '0x7e', '0x86', '0x8e', '0x94', '0x98', '0x99', '0x99', '0x98', '0x94', '0x92', '0x90', '0x8f', '0x8e', '0x90', '0x91', '0x91', '0x91', '0x91', '0x91', '0x90', '0x8c', '0x89', '0x82', '0x76', '0x70', '0x72', '0x73', '0x70', '0x6b', '0x67', '0x6c', '0x71', '0x78', '0x7f', '0x84', '0x87', '0x8c', '0x8f', '0x90', '0x8f', '0x8d', '0x89', '0x87', '0x83', '0x7d', '0x76', '0x70', '0x75', '0x7c', '0x80', '0x85', '0x87', '0x83', '0x7e', '0x7c', '0x7e', '0x7f', '0x80', '0x81', '0x82', '0x83', '0x83', '0x86', '0x88', '0x88', '0x87', '0x85', '0x83', '0x81', '0x7f', '0x7f', '0x7e', '0x7f', '0x7e', '0x7e', '0x7f', '0x7f', '0x7c', '0x78', '0x70', '0x6f', '0x73', '0x7a', '0x81', '0x86', '0x8b']
Checksum: 60620 check: 60620 pass: True
timestamp: '\x000\x000\x00:\x000\x004\x00:\x004\x006\x00.\x001\x002\x009'
