How to install BlueOS on arm64/v8
I am trying to install BlueOS on Raspbian Bullseye arm64/v8. Looking at other threads it seems that this is possible, but I don’t see install instructions.
Running the installer script results in an error: no matching manifest for linux/arm64/v8 in the manifest list entries, which makes sense.
Thanks,
/Clyde
I had the same error recently.
You can change the script and add the parameter --platform linux/arm/v8 e.g.
docker pull --platform linux/arm/v8 $IMAGE
Also, you will have to edit the file /home/pi/services/ardupilot_manager/firmware/FirmwareInstall.py in the blue-core image to remove the platform validation for the firmware, since the firmware is 32bit.
Hi @clyde,
I asked about this internally and was told we don’t have a v8 image built, so there’s no manifest for it at the moment. This issue is relevant.
Thanks! I’ll monitor progress on the issue.
I was able to install linux/arm/v8. But arm64 is missing
This PR isn’t finished yet.
It builds both images but we need to tweak it to generate both artifacts independently.
