I want to change to a camera with autofocus or a camera with sony imx291, how to do that?
Thank you very much!
Do you have a particular model in mind? Using a webcam should be possible, but I haven’t tried it yet.
-Jacob
@Jacob Yes, I’m camparing several models, I think the key is super high dynamic range and super low-level lighting, not the resolution
Maybe Hi3516a+imx290 with autofocus lens? Need to use wireless or Rj45 to usb…
How can I change the cradle from 2525 to 3838?Thank you for any help!
Got the answer from docs!
Hi Ooyama, we’ve got some samples on the way of a low-light digital camera that can stream at full HD resolution. We’ll be testing it in the next few weeks. It has the standard 38x38mm hole pattern.
Hi Rusty,
Thank you for your reply, I’m looking forward to the new digital camera, btw, what’s the sensor of that camera?
Best regards,
ooyama
Hi Ooyama,
We’re just testing this so it’s not for sure yet. The sensor is IMX322. It is a larger sensor with good low-light capabilities.
