List,
I am having some trouble getting servos to work with a Pixhawk 4 mini, Ardusub, and Qgroundcontrol. The problem comes down to me not understanding how to map servos to buttons on my Xbox controller. Right now, my configuration follows the Pixhawk 4 mini wiring guide found here Pixhawk 4 Mini Wiring Quickstart · PX4 v1.9.0 User Guide. I have checked all the hardware from thrusters, ESC’s, BEC, and servos to make sure they are functioning. The Pixhawk also seems to work fine and can control thrusters. I have also attempted to map servos to buttons via qgroundcontrol and I think this is perhaps where I am confused. With the Pixhawk 4 I can just attach servos in order on the rail and then map buttons using the servo_n functions to the Xbox joystick and it works. With the mini I’m not sure how to map the main out pin to a button on the joystick via qgroundcontrol. I suspect I am missing something simple but after spending a lot of time on this I am stumped. I have added three images that might help. The first is a stripped-down test with the Pixhawk 4 mini. There is one thruster connected via bidirectional ESC and a single servo, also on main out, and is powered by a BEC on pin 8. Any help is appreciated.
