Ok @Spipp -
I may take a stab at doing this with NodeRed - I’ll update this guide if it works!
Can you share more about your requirements? You’d like to output the packet:
{,#HEADING,18.57,#DEPTH,-0.24,#PITCH,3.00196763110161,#ROLL,-4.43289819562435,#TEMP1,54.08,#TEMP2,22.17,#BATVOLT,15.713,#,0,#S1,1500,#S2,1500,#S3,1500,#S4,1500,#S5,1500,#S6,1500,#S7,1500,#S8,1500,}
At what frequency?Are the S# values referring to the 8 servo outputs?
You’d like this packet sent via UDP to a specific address - 192.168.2.1 for the host computer? What port?
Is this is to interface with software called Oceanvault? If that’s the correct software, I’d point out you can technically configure QGC to overlay this on your video recording (played with VLC media player) via .ass subtitle file by configuring the instrument panel at the bottom center of the interface to display your desired values - although I’m not sure the servo positions are available, everything else is!
When played from the Documents/QGroundControl//Video folder, with the subtitle file name the same as the video file, VLC will overlay the telemetry on the bottom of the screen.
Cockpit can also do this, but may not have as many values available for you to use (yet).
