@Rusty- any thoughts on the in-water drag for a vertical decent of my rov? I am trying to plan descent and ascent power management. My configuration would show a flat-board plane of 4" x 10", plus the cross section of two T-100s. I figure you guys have looked at this in your design work.
That’s not my area of expertise unfortunately. I do think you’ll hit terminal velocity almost instantly so the best way to figure this out is probably experimentally. Make it 1 lb negatively buoyant and then measure the time it takes to sink a few feet.
Yeah, good point Rusty. The time it takes to reach bottom with 1 lb negative buoyancy should equate to 1 lb of down thrust, which I can equate directly to motor current draw. Easy, peasy. Thanks
