Fathom X over long tether
We are currently working on a custom project, and are considering using the Fathom-X as an alternative to fibre optics. Does anyone have any experience using these boards on longer tethers? For our project, we need a custom tether 800 meters long, with both 400 VDC supply and communication (twisted pair if we go for the Fathom-X). I realize that the electrical characteristics of the tether itself will play a large role, but the information on the board mentioned a theoretical 2000 meter max tether length, so it would be interesting to hear if anyone has tried using them with longer tethers, and what their experiences were.
Looking forward to hearing from you guys! :slight_smile:
I’m using Fathom-X for communication on a pipe rover. It’s works (more than 10 mbit/s, no precise tests done) over 750m on a cheap AWG24 shielded twisted pair(not working with the same cable over 800m). AWG22 shielded twisted pair should do the job for the communication part.
Magnificent, thank you very much for the input! :smiley: That is very helpful information. I could reduce the length to 750 m if needed, so then at least I know it is possible.
You can also consider the WisPLC Pro from Rakwireless. It is effectively a newer/more capable version (LX200V30) of the FXTI (LX200V20).
Some iperf3 results from our tests with BR tethers - so unshielded twisted pairs:
I use this now…
eKL IP Extender Kit
Over Coax Cable Up to 6560ft (2000m)
Hi @Oddmar can you please tell me how to set this in the bluerov… I´m trying to use a very long tether (700 m) and want to use the or try the best option. Thank you very much…
Well, i use a 4-port router between my Rpi and the eKL extender so i can run 8 camera feeds from an onboard DVR, but most people would just plug the Raspberry Pi into the eKL ethernet extender, then run coax or cat5 cable up topside. eKL ethernet extender topside plugged into computer.
thank you very much for the hint, I will try that…
Bonjour, vraiment très intéressant pour gagner en portée de communication ! Avez-vous une photo pour montrer votre branchement ainsi que les câbles que vous utilisez ?
Merci d’avance !
No parley vous fransai. English…lol.
