External INS+DVL system for Navigator Flight controller board
I hope you are well.
I’d like to ask about the possibility of integrating an external INS and DVL system with the Navigator board. I have reviewed the parameters available in ArduSub 4.5.6 (stable) via the BlueOS autopilot interface. While I noticed options to specify yaw, position, and velocity sources using the EK3_SRC**** parameters, I did not find a parameter that directly allows selection of an external IMU (for example, INS_USE does not appear to support this).
Could you please clarify whether it is possible to fully replace the onboard INS with an external system? If so, I would appreciate any recommendations you might have for compatible INS and DVL sensors, as well as any guidance or documentation on how to proceed with the integration.
Thank you very much for your assistance.
Best regards,
Thomas
Bump! I am curious about this too :slight_smile:
Hi @thomas_G / @AshROC,
As I understand it ArduPilot’s External AHRS functionality (accessible via AHRS_EKF_TYPE) allows either fully replacing the autopilot’s EKF in favour of an external estimator, or (depending on the backend) just using an external setup as a sensor set (in which case it seems the IMU would need to be included in EAHRS_SENSORS, likely with relevant ExternalNav values set in the EK3_SRC parameters).
I’m aware WaterLinked’s DVL offerings include an AHRS, so could be a candidate for developing a new EAHRS backend to support using that (and/or the sensors in it). I imagine other high end systems would also include them.
