When reading the information on the M200 I came across the next statement in the “Learn” section:
"## Notes
It is strongly recommended to insulate the motor. Over time, without insulation, the wires will begin to show signs of corrosion."
When looking at the T200 thruster information, no extra work is needed (at least it’s not stated to be needed) to protect it from corrosion.
What should I do to protect the M200 from corrosion? Is it just about potting the cable connections to the motor? Or should the M200 stator and rotor be potted?
