Depth Hold Mode Does Not Hold at 1 Meter How to Set Target Depth Autonomously?
A couple of questions:
  1. Does the vehicle start out wobbling, and stabilise to level once that motor’s output is decreased?
  2. Have you checked that the thruster actually works?
    • When the vehicle is off/disarmed, the propeller should be able to move freely when spun by hand
    • If you try actuating just that motor in the Motor Test section of BlueOS (in Vehicle Setup / PWM Outputs), does the motor spin as expected?
