Hi there,
I am wondering what is the average delay in milliseconds between topside computer connected to the computer (raspberry/Jetson/navigator in the same network using the switch inside BlueROV) using 100m tether (1 pair cupper wire with HomePlug protocol basically using xfathom)
Would you please share your results like what is output if you make command
ping 192.168.2.2 (or whatever IP address you using for computer located inside ROV)
Cheers
Nurjan
