Hi Jacob, thanks for image 0.0.18.
That made my Ping360 work fine.
Very nice work with the UI and plug&play functions in Pingviewer!
More about Ping360 in separate thread
About Companion automatic update in my system that still not work after 0.0.18
Reason this is useful is partly that acess Raspberry SD card is not easy, partly that aluminium tube generation 1 is difficult to open/close.
There is unsolved case with logs in old thread.
Companion image/version has always bin BR standard.
Update did work in version like 0.0.15 or so
Network and internet access has always been tested with other stuff like computers to check the ISP line.
Old tests from different networks and setting:
From january case
From recent tests I have logs from iPhone network sharing only, version 0.0.17 and 0.0.18
This also tested anr working with other clients then Raspberry/Companinon
Now UI indicate network access, but no internet. (Tested and working with other clients)
Bo0_0_18_iPhone_webui.log (40.8 KB) 0_0_17iPhone_webui.log (508.6 KB)
