my BR2 was running an older companion ( 0.0.17 ) and an older firmware ( 3.5.4 ) with no particular issues .
It was not possible for me to update the companion and the PX4 firmware trough the companion web interface, because no updates were showing up ( I had a look to the related posts to make sure I was doing it right ) , so I had to manually update them by flashing the RPI SD card ,and then to manually upload the Pixhawk firmware trough the Web interface.
Both have been updated to the latest ( 0.0.22 and 4.0.1 , same for the QGC which has updated to the last version .
Since this update I noticed some more delay with the commands sent to the ROV ( the response of the ROV is a bit sluggish ) .
Here some pictures: The CPU load is running at 40-50% idle , with the temp going to 80°C and the " current arm frequency capped " warning.
Hi david,
i am also facing the same issue, while the temperature is under 75 c the ROV working properly as the temperature exceeds they response become sluggish.
if you resolve the issue please let me know , i will be very thankful to you.
if i place a cooling fan on the processor , how it will work as there is no heat exchange within the enclosure? i really don’t understand. Help me in this regard…
thanking you.
