I have been out testing it today, the rangefinder function do not work after the update. It get some errors in the dvl-service:
PosHold seems to work fine.
Here is a video from todays dive in Saltstraumen Northen Norway
That looks like an internal error with mavlink2rest - Iāve passed it on to the dev team and will get back to you as soon as I can. Apologies that there seems to be a new error here, I thought these things had been checked before it was released.
Beautiful footage, thanks for sharing ![]()
Iām told this is fixed now. Apparently a mavlink message got changed (unexpectedly) without us knowing about it, so one of the fields was missing and it wasnāt parsing correctly.
Only error showing up now is : " Error fetching data for DVL: āvxā "
Rangefinder is working. We have only tested it our tank this morning, so im gonna give you a feedback when we have been in Saltstraumen testing.
Thanks for the fast feedback @EliotBR
Given itās seemingly working then thatās likely not a problem, but Iāve passed it on to the software team in case it does need to be fixed. Iām unsure if itās complaining that the DVL is not returning a sideways velocity, or if the DVL is requesting/wanting one from the ROVās IMU and not getting it.
EDIT: Just had a quick look at the dvl code and it seems like that error message occurs if a message from the dvl doesnāt include the expected components. If the velocity and position are updating correctly then likely thatās just caused by unrelated messages, which ideally should be handled separately but shouldnāt make a functional difference to the performance, but if the position and velocity arenāt updating at all on the map then there are bigger issues at play.
Alright, cool. Hopefully itās all working correctly now, but let me know if anything else comes up. I should at least have a response by tomorrow on whether the āvxā error is a problem ![]()
No worries - thanks for your fast confirmations and responses, with error messages included. It makes it much easier for problems to get fixed efficiently ![]()
Here is the log.
Position hold is working, rangefinder is working. I tried to set new origin but i did not get an update on the map.
We are live from saltstraumen: Twitch
Good to hear! Pretty sure the error message is just from the current parser, which tries to treat every message like a velocity message. The Water Linked DVL API mentions a position report message that gets sent at 5Hz, which seems reasonably close to the error rate your log shows. I made an (untested) pull request to fix the issue here, but Iāll have to let the software team determine if thatās the right course of action.
I havenāt used the dvl setup before, so out of my depth with this one - have passed it on.
Yes everything is working now, we are using the DVL on daily dives in Saltstraumen
We are also using UGPS G2 there to get position. But the new dead reckoning function in the DVL software is working great for navigating.
That PR is now merged, but itās not yet ported into the current release because itās non-essential, and likely better to include in the next meaningful release instead of polluting the 0.0.28 build with various versions that we canāt tell the difference between without checking code.
Unless youāre using your own custom code to set that up, the new dead reckoning message is currently not actually being used by ArduSub. ArduSub does its own dead reckoning using the velocity measurements fed in from the DVL, which is what our dvl branch is for. Amusingly the dead reckoning position messages are actually the cause of the āError fetching data for DVL: āvxāā issue - previously there was only the velocity message type, so there was no reason to handle anything else, but now there are also regular position messages, and they werenāt being handled in a nice way in our dvl code.
That being said, weāre planning to do a comparison of the position outputs from [ArduSub+DVL velocities] vs the [DVL position] outputs, because itās possible the ArduSub results could be made (even) more robust by taking in the DVL position estimates instead of measured velocities. Glad that it seems to be working well for now though in the current state ![]()
Thanks for the help. Awesome work you and your team are doing
Keep up the good work ![]()
Well, I bit the bullet and updated by following following the dvl installation instructions. Now I have video, but no connection.
Odd - I just did the install via git and get the same companion āVersionā as you, and it connects fine to my autopilot. It also seems to have worked for Al and Willian, so this seems like an isolated issue.
A few questions:
That all looks normal to me, except the not being able to connect. Are your companion and topside computer on the 192.168.2.x sub-net? Since the video is getting through you can check that by the IP address thatās in the gstreamer settings from the Camera page (and your companion IP address is the one youāre using to access the web interface).
Beyond that my best suggestion is going through the relevant troubleshooting steps (weāve already covered some). Iāve flagged this with the software team already, since it seems unexpected given your system was working before the update.
Working through the troubleshooting steps :
Verify Autopilot USB Connection; I can connect to QGC with the USB cable connected directly to the laptop.
Check MAVProxy section; These are the results after entering the screen -r mavproxy command:
I reinstalled Ardusub by connecting the Pixhawk directly to the PC and using QGCās firmware upgrade application.
Iām not sure what to try next, besides starting to replace hardware, but Iām pretty sure thatās not the problem.
Hi @gcelec ,
It looks like your update failed somehow. I have been seeing issues with pypi.org a lot more than Iād like tooā¦
I recommend you either flash the new image, or try installing the missing dependencies:
As it is missing āfutureā, run sudo pip install future and reboot. Hopefully that is enough.
I flashed a new Companion image to the Pi micro SD card at now I have a vehicle connection.
Thanks.
