Cockpit startup map location
How can the initial starting point for the cockpit map be set to someplace other than the southern hemisphere?
Right now it can’t :sweat_smile:
As it’s relatively straightforward, I will push a PR in the next hours adding that.
Edit: PR open. Should be available tomorrow on v1.7.2.
@oceanq you can now do it on 1.8.0.
For that you can use the mission settings in the main menu or just click on a place in the map and select “Set default position”.
Awesome! Thank you! I’ll try it out asap!
