I have several points on which I seek clarification or confirmation regarding the test conditions during the assessment of the ROV’s maximum specifications as stated in the datasheet / technical reference:
Bollard Thrust:
Forward (45°): 9 kgf
Vertical: 7 kgf
Lateral (45°): 9 kgf
Here are my questions:
Operating Voltage and Current Drawn: Could you specify the operating voltage and the current drawn by the ROV when it was generating its maximum force?
Is there time series data of the bollard tests including the force, battery voltage, current and esc control signals that could be shared?
Specifically, I’m interested in the voltage drop during your bollard thrust measurements.
The vertical bollard thrust scenario was also discussed in the “Thruster Force” topic, mentioning
Assuming a fully charged battery at 16.8 v/ 4.2 v per cell, under a 50 A load the cell voltage could
be expected to drop to about 3.8 v, or ~15.2 v total. -
From own measurements I can confirm that voltage drop can be around 2 V @ 50 A and 3V @ 75 A.
Battery Voltage Confirmation: Can you confirm that the battery used was initially charged to a voltage of 16.8 V for these tests?
Test Environment: Was the BlueROV tested in a tank fully submerged, similar to the single thruster tests, as detailed in the
T200-Public-Performance-Data-10-20V-September-2019.xlsxand shown in this article thruster test stand ?- And/or was a different, alternative setup used, such as an open-water experiment in a sea or lake, involving the actual pulling of a steel rope?
Measurement Uncertainty: What was the uncertainty (standard deviation) associated with the force measurements?
