CHANGE MODE FAILED
I used the example of change flight mode, in order to change to STABILIZE mode, but the terminal printed ‘Command executed, but failed’.
Even though I had changed the firmware to ardusub, I printed MAV_TYPE and found that it was ‘fixed wing’, not ‘submarine’.
from pymavlink import mavutil
import time
# Create the connection
# Need to provide the serial port and baudrate
master = mavutil.mavlink_connection(
            '/dev/ttyACM0',
            baud=115200)
mav_type=master.field('HEARTBEAT', 'type', master.mav_type)
print(mav_type)
The above program prints 1, and the following figure shows that this is a fixed wing.
How do I solve this problem?Thank you.
Probably is triggering a failsafe, check the sensor status and try to set stabilize mode via QGC.
Add master.wait_heartbeat() before checking the field, it’ll print 12 (MAV_TYPE_SUBMARINE).
Thank you very much!!!
Your reply helped me solve this problem perfectly!!!
I’m glad that everything went well, let us know if you need any further help.
