I’m trying to get the pymavlink connection up and running using the instructions found here.
I’ve followed everything (I think) correctly and have my surface computer connected to the pi and the pi connected to the pixhawk. I can open up QGroundControl and see the connection being made properly and can even open up the companion web app on http://192.168.2.2:2770
I’m now trying to pull some data using the pymavlink instructions, but it doesn’t seem to be working properly. I’m running the default one without QGroundControl open, and it doesn’t seem to print out anything. If I force it to print out an error it gives me, “print(master.recv_match().to_dict()) AttributeError: ‘NoneType’ object has no attribute ‘to_dict’”
Here’s the script I’m running:
import time
from pymavlink import mavutil
master = mavutil.mavlink_connection('udpin:192.168.2.1:14550')
# Get some information !
while True:
try:
except:
pass
time.sleep(0.1)
Any help would be super appreciated!
