Cannot update BlueOS
I’m running BlueOS 1.4.0. on the Blueboat. I cannot upgrade or downgrade BlueOS versions.
Pushing “Download and apply” on any versions (stable, beta, master, latest) downloads stuff and it looks like it’s downloading something, but when the screen refreshes it says its at 1.4.0 still:
I can apply the “Factory” local version and go back to version 1.4.0, but nothing else works. It has internet connection.
Also, not sure if this is related, but I cannot get to the extensions page anymore:
How can I fix this?
Hi @CA_BlueBoat -
If you can’t load the extensions page, something is blocking your access to the internet! If you’re not able to update to 1.4.2, you could download and flash the SD card manually as detailed here.
Hi Tony,
I’m connected to the internet:
I have a bunch of ROS stuff and other drivers, so it would be a real pain to reflash the SD card.
If i click “Download and apply V1.4.2” for example, it will go through and download stuff:
Hi @CA_BlueBoat -
That looks like the update is happening correctly - it just needs sufficient time and bandwidth to complete! Are you saying leaving that screen up doesn’t result in BlueOS restarting at the new version?
