If yes then please explain something
Hi, yes I believe you can.
Can I ask for what will you be using the flight controller?
Cheers
pob747
for pisciculture
Hi @rajesh -
While you could use the Navigator with an AUV, this is not a supported use-case by default. You would need position information for Ardusub to perform navigation autonomously - this can be done with DVL or water link GPS system. I’d recommend developing your vehicle with a tether, verifying auto mode, and then removing the tether and communicating with the vehicle via WiFi with it at the surface to initiate a mission. Best of luck!
