Call for Practical Experiences & Media: Improving Visibility in Murky Water (Lighting, Filters, Cameras & AI)
Hello everyone,
For an in-depth practical article on Unterwasserpilot (a German-language online publication and forum for ROVs and underwater drones), I am currently researching optical visibility improvement and image optimization in turbid or murky waters (suspended solids, algae, sediment).
Important Note: We are deliberately excluding sonar, acoustics, and radar systems for this article. The sole focus is on how to extract the absolute maximum from the optical camera signal.
What I Am Looking For:
I am searching for first-hand practical experiences, test series, side-by-side comparisons, or specific hardware/software setups—ideally supported by photo or video footage:
1. Lighting Setup & Geometry
  • Distance & Angles: What separation distance (base distance) between the camera sensor and light source has worked best for you to minimize backscatter? What beam angles deliver the clearest results in low visibility?
  • Color Temperature & Lumens: Do you use cold white (>6000 K), warm white (3000–4000 K), or yellow-filtered light? How many lumens actually make sense in murky water before you end up staring at a “white wall” of reflection?
  • Do you have any documentation, test results, or measurements on this?
2. Cameras, Lenses & Sensors
  • Camera Technology: Which sensors (e.g., Sony STARVIS / low-light sensors) or manual settings (ISO, gain, shutter speed) do you rely on to keep digital noise low?
  • Filters & Accessories: Have you experimented with polarizing filters (cross-polarization), color filters, or specific dome/flat ports to enhance contrast?
3. Software, Live Processing & AI Enhancement
  • Do you use software tools or algorithms for real-time image enhancement (e.g., de-hazing, CLAHE histogram equalization, custom OpenCV pipelines)?
  • Has anyone used AI-based models or deep learning tools for de-hazing, noise reduction, or color restoration in your video feed or post-processing?
What Is In It For You:
If your insights, setups, or before-and-after footage are featured in the article, you (or your organization, project, or channel) will be credited, highlighted, and linked in the published piece upon request.
Please feel free to share your thoughts in the comments or send me a direct message!
Thank you very much for your support!
Hi @Unterwasserpilot -
Welcome to the forums!
I replied to your post on reddit/r/rov - is that how you found your way here?
As others commented on that thread, there is no “magic bullet” that will make turbid water possible to see through, at least that I’m aware of! Capable sonars are getting more affordable all the time though!
In answer to your questions:
  1. Maximize the seperation between light source and camera, and if possible make sure they are not pointed parallel - you want backscatter from particles to not be reflected towards the camera.
    Generally no artificial light is going to give the best picture, assuming ambient sunlight is available. I’m not sure what documentation or measurements of this would look like - turbidity vs. visible distance?
  2. The USB low-light camera has been standard in the BlueROV2 for many years - it uses the Sony Exmor IMX322 / IMX323 (as noted on the product page, Technical Details section.) It is quite good in low light, however the newly launched 4k Cam is even better, with a much larger Sony IMX678 CMOS 1/1.8" sensor. The default settings on this camera maximize visibility, and were selected after testing in numerous environments. The “one-push” white balance function is typically all that is necessary for a user to achieve great color and visibility when piloting the ROV!
    A flat-port is going to introduce a lot of distortion vs. a camera properly located in a dome. I don’t think a polarizing filter would have much of an affect underwater, but it certainly would when out of water and trying to look through it…
  3. The 4k cam by default has a de-hazing setting active. Colors are improved in real-time by the AWB function as mentioned.
I’m eager to see if any of the community has other tips to share!
After many years as a diving underwater photographer, then moving onto ROVs, I can offer you one simple bit of advice when it comes to lighting to avoid backscatter:
There is not one single, simple setup - ideal setup changes with visibility, camera FOV, lighting intensity, and subject distance.
The illustration below show a very simple representation of lighting - you must aim to illuminate the subject, and not the water particulate.
The displayed angle will change with subject distance, however, the light intensity will also affect the required light fixture angle. Camera FOV will change the light fixture position - the light fixture is naturally desired to be out of image FOV, so if shooting tight FOV, the lighting has much more out of shot space to be, while shooting wider angles, there is less ‘out of shot’ space for lighting fixture position. Don’t forget that off-board lights may be the only option, where the lights are placed elsewhere, illuminating the subject, and not attached to the camera. For more distance, this can be the only option. When James Cameron shot the Titanic (the real wreck) he had ROVs dedicated to lighting completely separate from the camera ROV. The one single image that started my in-water obsession was only possible due to off board lighting, although the visibility is generally good - though that is relative, onboard lighting would have achieved predominantly black image, with only the cave passage roof illuminated.
Captured by the late, great Wes C Skiles :folded_hands:
Traditional tungsten temperature lights (in my experience) have always created less backscatter than ‘daylight’ lighting.
I can highly recommend you look up Alex Mustard for his online strobe positioning workshops.
Thank you both, @Tony_White and @3dMB, this was really helpful!
Tony, your advice to separate the lights from the camera and not point them in parallel, and Marcus, your point about lighting the subject instead of the particles and that tungsten light gave you less backscatter, both ended up in my article on improving visibility in murky water.
I would like to mention you both in the article as a thank you. How would you like to be credited? For example your full name, just your forum name, or a link to a website or channel of yours. If you prefer not to be named, that is fine too.
I will also link to this thread and mention the Blue Robotics forum in the article, so that others can find the discussion.
I will not publish anything with your names before you have answered. Thanks again for taking the time.
There are some relevant visibility improvement approaches presented in this post.
Beyond that, I quite like the breakdown of light travel and colour handling in the SeaThru paper, and the underlying ideas and data have since been expanded into SeaThru-NeRF and SeaSplat. To some extent they can be worked into real time processing if you have range estimates for different portions of your image (e.g. from stereo cameras), along with estimates of water colour and strength and colour of on-vehicle vs external sources of illumination, but they’re currently presented as post-processing approaches.
In terms of turbidity and haze there are various companies and researchers working on that, to varying degrees of success. There are some fundamental limitations to visibility range, but there is definitely scope to improve signal quality beyond a pure camera stream with temporal filtering (e.g. seeing which parts of the image persist over time), and (depending on what you’re trying to view) structure detection/enhancement (e.g. using edge detection algorithms). Traditional computer vision algorithms may have more deterministic/repeatable results on the same images, but it’s hard to avoid at least some amount of parameter tuning from data, at which point every approach becomes machine learning to some extent, and it’s mostly a question of whether there’s enough data and compute available to hand off more of the structure determination to the training process, or if some/much of that needs to be predefined in a hand-written algorithm. I’m aware that’s mostly theoretical insight - unfortunately I don’t have shareable practical examples available at front of mind.
For what it’s worth, the Blue Robotics Lumen lights are controlled with an exponential brightness curve so there’s extra fidelity in the low brightness regions, where there’s less backscatter and a lower risk of saturating the image sensor from bright scene regions. One way of dealing with “the light is shining back at me too much” is to just use less light (though of course that does reduce the total distance that can be seen, compared to more light in clear water).
