Building your own 14.8V 18000mAh battery
Due to shipping restrictions we were not able to purchase the battery from Blue Robotics.
If this is the case for you, do not be alarmed. Building your own is not too difficult.
Here’s your shopping list:
Heat Shrink Tubing: Wide 180MM / Diameter 115MM PVC 2:1 Heat Shrink Tubing Battery Wrap Black/Red/Yellow/Green/Blue/White/Clear|Cable Sleeves| - AliExpress
Heat resistant tape: https://www.aliexpress.com/item/10mm-X-100Ft-Gold-High-Temperature-Heat-Resistant-Kapton-Tape-Polyimide-BGA-Free-shipping/32780815592.html?spm=a2g0s.9042311.0.0.ykJ102
10AWG silicone wire: 10awg Flexible Silicone Wire Tinned Copper Wire Stranded Wire 10awg 1050 / 0.08ts Outer Diameter 5.5mm 5.3mm Wire And Cable - Electrical Wires - AliExpress
Nickel strips: 100pcs/lot 0.15mm X 7mm X 100mm Quality Low Resistance 99.96% Pure Nickel Strip Sheets For Battery Spot Welding Machine - Spot Welders - AliExpress
Eva foam: Happyxuan 5 Pcs/lot 49*47cm 2mm Eva Foam Sheet Cosplay White Black Green Color Sponge Paper Diy Handcraft Materials Colorful - Puzzles - AliExpress
Spot Welder: Spot Welder With Led Light Battery Welder Applicable Notebook & Phone Battery Precision Welding Pedal 787a+ Battery Spot Welder - Spot Welders - AliExpress
XT90 connectors: Original Amass 10 Pairs Xt30 Xt30u Xt60 Xt90 Mr30 Xt60h Bullet Connector Plug Male Female For Rc Fpv Lipo Battery Rc Quadcopter - Parts & Accs - AliExpress
JST-XH 4S wire and connector: https://www.lazada.com.ph/set-of-10-30cm-jst-xh-4s-lipo-balance-wire-extension-leads-cables-681849.html
For the batteries, we purchased them from a local vape shop. We couldn’t get the same brand as the ones used in the BR battery but we got an equivalent. The one we got was LG Choco: https://www.mistwoodvape.com/collections/power/products/lg-choco
On top of that, you will need a soldering iron, glue gun and PPE.
Here is the drawing of the battery assembly:
Note that this is a 4S6P whith means that you need to connect 4 banks in series to get to the required voltage (3.7V*4=14.8) and each bank has 6 batteries in parallel to get the required mAh. (3000mAh * 6 = 18000mAh)
Here is the pattern we chose for this project:
Side 1
Side 2
Here are some fabrication pictures and the finished product: (be kind its our first try)
After building this first battery, I found that the shrink wrap we got was a bit too wide, I would recommend a smaller diameter to do a nicer finish.
Note that the fitting inside the 3inch enclosure is tight so you have to keep everything as low profile as possible.
If it’s of any interest, I can put a link of the final procedure and job safety analysis. Let me know.
In conclusion, it would take 3 batteries for us to break even. I would still recommend BR’s battery if you can get it shipped. There are considerable risks involved in making this. Make sure you know what you are doing, never solder directly on the batteries and protect the contacts with electrical tape when you are doing your manipulations.
Cheers,
E.
What is the total cost for this DIY battery?
It cost me about 150USD for 24 batteries
The rest of the material come in bulk and cost me about 140USD
The welding machine cost me about 85USD
So 375USD all in with shipping and enough material to make about 10 batteries (except for the silicone wire)
So lets say 175USD per additional battery
I also bought a 400W charger which is why I mentioned I would break even with 3 batteries. I won’t post the link to this charger as it would compete with BR’s charger which would be a d**k move.
If you are in Europe, they can be shipped from Nido Robotics
Hello all,
I just thought I’d share my experience with the battery packs I made.
The LG Choco turned out to be a very bad choice. Multiple failures if you go over 50% gain.
I am now using Enook 3200mAh batteries which works very well. I have clocked 4 hours with 25% lights on all the time and 25% thrust. Continuously on depth hold or stabilize.
Cheers,
E.
Hi Etienne,
Thanks for sharing this. In my day job we have been producing batteries in a very similar fashion to your technique and, after a couple of fires and a refusal to ship from a major shipping company, we had a major review meeting today to discuss our ongoing battery strategy. I’ll sum it up as follows:
  1. We will no longer build battery packs in-house.
  2. We will lay out a specific set of designs and outsource to pro battery manufacturers.
  3. They will produce the batteries and provide the necessary QA/QC documents along with a Safety Data Sheet (SDS).
From our experience, it is worth noting that if you get a failed cell it can drop its internal resistance and then overload all the other cells in the circuit, this results in a minor fire which gets progressively worse. I can’t share the ugly photos but we were very lucky that nobody was injured.
Furthermore, there are now cells which have internal protection like this one. We are going to be testing them but it’s worth noting that all these cells have guarantees and SDS’s but all those assurances disappear once you start packing them in combined battery packs.
This is where we get into the everlasting argument between Li-Ion and LiPo. I’ve been flying drones with LiPo’s for 8 years and the charger will tell you when it’s time to retire a battery but Li-Ions can get very scary without any warning - just take a look at the e-cigarette videos on Youtube.
After all my research, I am happy to continue with LiPo. This isn’t an empirical decision - it’s just a gut feeling from previous experience.
SROV.
Thanks for Sharing,
I agree that assembling these batteries is a bit risky. The negative pole wraps up all the way around so its easy to short and have a fire for sure.
The choice of batteries is a big factor unfortunately, I am limited to what is available here in the Philippines.
The Enook have not given me any issues to date so hopefully they will prove to last long enough until I get the surface power sorted out.
Cheers,
E
It would increase your cost but for a little bit of added security and redundancy you can get a protection board to regulate your batteries and improve their life. For aerial operations where weight is huge factor I could see skipping it, but for dive batteries or any ‘really big juice’ packs I wouldn’t go without… My dive batteries see a lot of abuse and the protection boards have saved me from some very nasty accidents. They’re solid state and can be potted right into your battery unit if your solder connections are good.
edit: Also as others have stated, you want avoid cheap vape or offbrand batteries at all costs, although I get it may be hard to find good batteries in some parts of the world. Cheap Li-Ion batteries are not made to the same standards and are more prone to catastrophic failure. There is a fair bit research on this; NASA did failure tests on a handful of manufacturers, and they send 18650’s into space incidentally. I use Panasonic for 18650.
how would i go about getting a better detailed plans on building this battery?
When building batteries in-house, there are a couple things you can do to prevent fires and accidents, charge and balance correctly, and make a safer battery in general.
  • Design your battery with fusible links ( Tesla-Style ) and solid metal bus bars rather than using welded nickel strips. If the internal resistance of a battery gets very high, or the capacity of the battery falls far below the others, using a glass fuse or a piece of 1/4 W resistor wire metal will break and drop it out of the cell.
  • Always use a BMS in your pack to charge and monitor it. I use a variety of BMS’es for LiCobalt chemistry batteries such as this 4S controller : http://a.co/d/2UIscbm
  • When building packs, don’t trust the cell manufacturer! Test each cell and get the actual mAh rating for each one, and match cells as closely as possible in each parallel line and if possible in the series for maximum capacity. The investment in time to do this is well worth it for reliability down the road.
  • Invest in a non-contact IR thermometer, and if you can afford it – a FLIR module. Charge and discharge the packs after you build them and see if any cells or bus bars are getting hotter than they should.
How and how many do you use?
I don’t understand the question.
There are 24 batteries per unit as explained in my previous post…
aaaa sorry i didnt see that one :wink: …i just googled it and found 2?..and thought this caaant be right;) Sorry mate :wink:
@etienne,
how exactly connect the two lower banks with the two upper banks of batteries?
mike
With the same wire as the ones used for the output connector.
@etienne,
so you don’t use spot welder for the specific spot, you just weld thick wires (10awg) is that right? Have you any photos to check your connection?
mike
Not sure I understand. I use spot welder except for connecting the stack.
The pictures I have are at the start of this post.
I don’t build batteries anymore.
@etienne,
may I ask you, why you don’t build batteries anymore?
mike
I build power supplies instead. I also got a supplier who builds them cheaper than my cost so there is no point unless I am prototyping.
Care to share your supplier? I’ve had two lithium fires, and I’m ready to get out of the battery building game…
