Bootstrap Docker "cannot mount volume over exiting file"
Every so often after powering off the raspberry pi the bootstrap docker container fails to create the core container.
It gives these sort of errors in the logs:
Starting bluerobotics/blueos-core
/bootstrap/bootstrap.py:189: UserWarning: Error trying to start image: 500 Server Error for http+docker://localhost/v1.41/containers/create?name=blueos-core: Internal Server Error ("cannot mount volume over existing file, file exists /var/lib/docker/overlay2/6db9954f230e7be8e61b8fc60269704a7edbaeb1cfbe7a0b1af9ddd95cb38734/merged/etc/machine-id"), reverting to default...
  warn(f"Error trying to start image: {error}, reverting to default...")
/bootstrap/bootstrap.py:189: UserWarning: Error trying to start image: 500 Server Error for http+docker://localhost/v1.41/containers/create?name=blueos-core: Internal Server Error ("cannot mount volume over existing file, file exists /var/lib/docker/overlay2/eebec0b04bb51cf597dee42acf29b26766cd46fc2ed0630fb133bf925c0283e2/merged/etc/dhcpcd.conf"), reverting to default...
Just wondering if there were any ideas as to why this is occurring. When I list the docker volumes, there are none, so I am not too sure why it tings it cannot mount the volume.
Hi @cpcp,
I don’t believe we’ve run into that before - thanks for reporting it!
So that we can try to replicate the issue, can you please specify
  1. the BlueOS version you’re running
    • it can be found at the bottom of the sidebar
  2. the hardware you’re running on
    • e.g. Raspberry Pi 3B / 4B
  3. whether you’re shutting down the Raspberry Pi before powering it off
  4. any other information you think may be relevant
    • it may help if you can upload the actual log file(s) instead of just a snippet
  1. BlueOS Version: heads/master-0-g956f4c4
    2.Raspberry Pi 4 Model B
  2. We are NOT shuttding down the Raspberry Pi before powering it off (we see this as possibly being a cause). However, even when using the proper “power-off” command it did happen once when rebooting it.
  3. Unfortunately, I have stopped/removed the container so I am not sure if I can still access the logs since it has been removed. I will upload them when the issue occurs again.
