I had similar problems some weeks ago. Eventually narrowed down the problem to three intermittent connections. The rov and ethernet box does not travel well and the two pin connectors come loose. We have put heat glue on the three suspect connections and the problem seems to be solved. Frustratingly simple after purchasing a heap of spares.
