Hi Everyone,
The engineering team I used to run had a BlueROV2, and I’ve seen or worked with a bunch of other organisations who all used a BlueROV2 and one of the most common things that I’ve seen people do is to add additional waterproof enclosures underneath in order to gain internal payload volume, usually for electronics.
I’m exploring some ideas to solve this by increasing the available internal payload volume in the main BlueROV2 tube by condensing the wiring and electronics. But before I commit a bunch of time and effort to this I wanted to understand how common the problem actually is, or if I just have a skewed perspective.
For those of you running custom payloads or companion systems:
- Have you ever run out of internal space?
- What payloads were you trying to integrate?
- What was the limiting factor (volume, wiring, power, cooling, buoyancy, something else)?
- How did you solve it?
- If you could free up a significant amount of internal space without changing the external vehicle dimensions, how valuable would that be to you?
I’m particularly interested in research, inspection and custom autonomy applications rather than stock vehicle configurations.
Assuming there is interest then I’d look to make this available as a 3rd part retro-fit kit/product.
Thanks,
Andrew
