Bluerobotics camera system
I am designing a Uncrewed surface vehicle and was planning on using the BlueRobotics camera but not sure if it meets my need. I am looking for 360 degree camera to aide in collision avoidance and wanted to connect to my Pixhawk 6 Flight controller. Does anyone have any suggestions?
Hi @vicsabelhaus -
The Blue Robotics low light camera could work for your application, but you would need to place it in an external enclosure and run an appropriate USB cable into the vehicle. This is also not a 360 degree camera! Cameras are not possible to connect to directly to the pixhawk - traditionally an analog camera is used on an independent radio transmission system (FPV) to view camera feed from drones - maybe something like that would work for you?
Thanks Tony. That does help.
