I have a USB camera connected to my Navigator board (Blueos 1.4). I can see the video under “video streams” in the BlusOS webpage:
Should the IP address of the “endpoints” be my GCS PC IP address?
In cockpit I added a “URLVideo player”. is that correct? What should this IP address be:
Thanks for the help!
Hi @CA_BlueBoat -
That is not the right Video widget to use! You should just be able to use the standard video widget, and it will auto populate the only stream that exists. You can see the list of streams Cockpit is receiving under settings / video.
You may also have better results with rtsp (instead of UDP) for your video stream type, especially over a WiFi connection…
