Hi! I am building the Blue ROV for our research lab and a I have a few noob questions about it. My idea is to test it first out of water to check the wiring using a Power Supply at 14V.
1- Is it fine to use a 14V power supply to test the setup out of water or with 5 meters of tether? Then we’ll buy a 4S LiPo battery probably.
2-Also, I wanted to know if it is possible to command the Blue ROV with QGC (using a XBOX joystick) connecting my PC to the Pixhawk through microUSB without using the RaspPi.
3-If I use the Raspberry Pi instead I have can use the microUSB connection with the RPi and the aux outs to power the RPi. Is this right?
4-When connecting the PixHawk with the thrusters’ ESCs, can I use the 3-pin connector provided with them or only the signal and ground pins (since the power comes from the power supply)?
Yes, it helps. Thanks for your quick reply Rusty!
1,3 Great!
Regarding to 2. I think that when the test setup works using the PC directly through microUSB (out of water), we will switch to use the PC to Rpi (through Ethernet) and RPi to Pixhawk (through microUSB). Is this setup right? We are won’t use the Fathom-S board because it wasn’t in store when we bought the BlueROV. Maybe we will order it in the future but now we can’t use it.
The 4 is the most confusing point for me… the ESCs have 2 inputs for power (we will power them with a LiPo battery or a temporary ground power supply) and a 3 pin connector (with power, ground and signal). As I understand you suggest to connect each signal main out pin to each ESC signal pin but all ESC grounds to a single ground out (MAIN OUT 1 -negative pin) and all ESC power pins to a single power out (MAIN OUT 1 +positive pin). Am I getting it right?
Correction. As described here Basic ESC Documentation (Old) the small red cable is an output (BEC Output), not an input so it shouldn’t be used, right? An then I should connect each yellow signal to each out of the pixhawk and also each brown ground cable to each negative out of the pixhawk for each thruster main output.
Hi DFornas,
You are right, the small red wire in the Basic ESC cable is a 5V output. It does not need to be connected to anything for the ESC to work.
The reason we recommend disconnecting all but one of those is because internally they are connected to a 5V linear regulator. Those regulators can actually fight against each other and overheat if they are connected together. We’ve had issues with it so I’d recommend cutting all but one.
Let me know if you have any other questions.
@DFornas,
Yes! You are correct on both points.
The Basic ESC BEC can only supply 500 mA (and it gets very hot) so it is not sufficient for the Raspberry Pi.
Thanks! I think it is all for now. Really nice replies, now I can work with a smaller chance of burning something
