I see that there are separate grounds for Power and the PWM signal. Are these isolated? In other words, if the motor 12v power ground is sitting at 1 volt above battery ground in a thick wire in my tether, and my signal ground is sitting at .1 volt above battery ground in a thin wire, will current try to gush through from the power ground which is driving the motors?
Thanks in advance
