I am trying to read data from Ping Sonar Altimeter and Echosounder with this code
But when I run it it gives an error.
(host, port) = args.udp.split(',')
ValueError: not enough values to unpack (expected 2, got 1)
I have connected the altimeter directly to Raspberry Pi with UART.
How can I fix that?
I change that line myPing.connect_udp(host, port)
to myPing.connect_udp("192.168.2.2", 9090)
and its working now.
EliotBR
(Eliot)
3
Is that from your code? There’s no line like that in the code example you linked to.
The actual code in the example is
(host, port) = args.udp.split(':')
which is used to convert a program command-line argument like --udp 192.168.2.2:9090
into a host IP and port number.
Hard-coding the values also works (as you’ve found), although it’s less versatile if you later decide to change the IP address or port.
