Adhesive to use when bonding syntactic foam
Hi All,
I am going to need to bond pieces of syntactic foam together and would like a recommendation for the type of adhesive to use.
Regards,
TCIII AVD
Hi there,
Others may work but the glue recommended to me by Trelleborg who manufacture Syntatic foam is 3M Scotch-Weld 1838 B/A.
Its a two part expoxy glue and I’ve used it to make several large buoyancy blocks for large ROVs and never had a failure.
Gavin
@nemorov,
Thanks for the suggestion, much appreciated.
Regards,
TCIII AVD
Hey @TCIII
Please be so kind to share your results :smiley:
Regards!
@luisgamez,
The 3M Scotch-Weld 1838 B/A is around $60 for the two part epoxy which is a little out of my league for hobby ROVs.
Rusty has recommended using the Loctite Marine epoxy and has indicated that he has achieved good results with that epoxy.
I will let you know how the Loctite Marine epoxy performs.
Regards,
TCIII AVD
Thanks TCIII !!!
@luisgamez,
The Loctite Marine Epoxy worked great and provided a solid bond between the two pieces of syntactic foam.
Since I am working with small pieces of syntactic foam I cannot attest to the shear strength of the bond, however the bond seam appears to be good and solid and will meet my modest structural requirements.
Regards,
TCIII AVD
Hi @TCIII
Thanks for your feedback I might need to do this bonding in the next couple of weeks!! ill proceed to use the marine loctite epoxy
