Add an option to Mirror scan on Ping 360
I finished my first Job with the Ping 360. it worked well though when I mounted the sonar in the horizontal (scanning in the vertical plane) the left and right are reversed. is there a way to Mirror the display? or can it be added to the ping software?
Yes, check the display settings in ping-viewer.
What setting is it? I assume the Head down box would mirror the display but it doesn’t seem to do anything.
We have fixed a bug with the head down configuration in our latest test version,
can you check if it fixes your issue ?
Thanks Patrick that did the trick.
