Ping360 positive experience, and alternative mounting
Thanks for a good product and competetive price with the new Ping360 sonar!
Real nice plug and play installation and use with Ping viewer.
One nice feature for future Pingviewer would be a function to keep settings like scan angle and range between sessions. Either making them persistent, or in memory accessible from UI.
I have made an alternative mounting, Ping360 is in front of the 3" tube, why:
+Less drag
+Less risk of hitting something above in tight spaces
+Less risk of damage at launch/recovery
+Less space during transports
-Downside: You can only scan 120 degree ahead, not a problem for me
Things that should make this easier to do:
-Rotation offset in Pingviewer, now the cable entry conflicts with 3" tube
-Memory function as described above.
-Another mounting bracket.
Bo
Thanks for your input, we are still working and improving ping-viewer, soon a new release may be available with new features :wink:
Such feature was removed before our first release, the feedback the we got was that such feature would not be used or confuse:
But I have created a feature request for it, hopefully we are going to have it soon:
This is a working in progress feature:
How did you mount it in the end Bo? We’re thinking to do the same.
Hi!
Works fine as picture.
Mounted by aluminium angleplate that is bolted to the battery tubes original screw threads.
Battery tube endplate secured with zip ties and glue to the 3" tube.
