Actual ID of 8mm penetrator
Hello.
Could you please verify that the actual ID of the 8mm perpetrators is fully 8mm. I’m trying to get a pair of 4mm OD hydraulic lines through and they don’t seem to fit.
thanks
Hi @johnbalison,
Our penetrators are sized by cable jacket OD, and intended to be used such that only the the insulated conductors pass fully through:
The throat ID of the 8 mm penetrator is 6.3 mm.
-Adam
