I purchased a 4" locking aluminum end cap with 14 M10 holes and was looking for a 2D drawing for it.
I don’t know how to get it from the 3D drawings and the documentation does not show this end cap anyway.
What are the 14 mm holes used for? Threaded holes seem unnecessary since all 12 penetrators and 2 blanks I have work fine. This end cap still seems to be available but are they being phased out?.
What am I missing?
Hi @Rov36 -
The 14mm holes are used with our larger WetLink Penetrators, like those used with the T500 thruster cable.
Some endcaps have threaded holes so that the penetrators can be assembled closer together. The 2D drawings can be found at the top of the technical details section:
If you need more detail, I would recommend downloading and reviewing the 3D model. It can be easiest to find these on the Technical Reference page. You can open this with free programs like AutoDesk Fusion for makers, or Onshape (my favorite!)
The 4" 14 hole M10 endcap is still available, and is not being phased out. The M14 versions are just providing more options!
Hello @tony-white
I can’t seem to find the 3D model for the 14 x M10 4" End Cap
It seems that the download link is missing from the Technical Reference page or maybe is labeled under another name. Is it possible to request this 3D model or show me where can I download it?
Best regards
Hi @Alex_UJI1,
The technical reference pulls model links from the technical details section of the relevant product page. While there is a 14 x M10 4" end cap selectable for purchase, we’re seemingly missing information about it in the technical details, so i’ve asked internally to see if we can get that information added ![]()
Following up, apparently the 14 hole end cap is part of the older ones, originally designed for our non-locking enclosure flanges. They’re compatible with the newer locking flanges, but the model information and technical details are (now) included in the last row of that technical reference table, rather than the row with the newer end caps we’re still manufacturing.
The model is WTE4-M-END-CAP-14-HOLE-R1.zip, and because it’s part of the older 6mm thick end caps the depth rating is 500m, compared to 1000m for the newer 10mm thick ones.
