QGround Control UDP
(David Ardis) #1
I have been trying to connect the BlueROV to a different laptop. On QGround control I can see aa picture but I cant arm or update any of the parameters. Looks like the firewall is not open but I have double checked and all firewall rules are in place. Any suggestions what I should try.
David Ardis
(ocenaman) #2
What is the OS version of your laptop ?
(Jacob) #3
If you can see the parameters at all, you should be able to edit them.
  • What parameters are you trying to change?
  • Do you get a warning when you try to arm?
This does not sound like a network/firewall configuration issue.
-Jacob
(David Ardis) #4
I am using a Panasonic FZ-G1 Toughpad running Windows 8.1.
This computer is attached to a coperate network and UDP ports 14550 and 5600 have been opened on the firewall.
I think this is a firewall issue Panasonic is receiving data and video and telemetry data but not transmitting anything.
David Ardis
(Jacob) #5
Hi David,
How have you determined that you don’t have any outgoing traffic? If you believe it is a firewall issue, you should try to get help from your network administrator.
-Jacob
(David Ardis) #6
Jacob
Not 100% sure but there is traffic going out. can you tell me what ports the are used both inbound and outbound i will then check against the firewall settings.
David Ardis
(Jacob) #7
The inbound ports are 5600 and 14550 outbound is determined by the OS on connection.
Can please you answer the questions in my previous post?
-Jacob
(David Ardis) #8
Jacob
Sorry In network status I am showing data out. I can arm the sub but none of the motors are turning.
David
(David Ardis) #9
Jacob
I have got all the connection problems sorted downloaded and install a new of the Companion Computer Software and reinsalled QGround Controll. After recalibration everthing is working.
David Ardis
(Jacob) #10
Wonderful! Let us know if you have any other questions.
-Jacob
