Seems like there is an error with my code, i tried setting pwm to 1550 then it armed. Anyone smart here wanna check around?
Its node JS. I’ll try to figure it out myself tomorrow but there are some timing issues yep… What my cheapo osci sees as 1500 is not correct
var i2c = require('i2c');
PCA9685 = function(address, device) {
var self = {
address: (typeof address !== 'undefined') ? address : 0x40,
device :(typeof device !== 'undefined') ? device : '/dev/i2c-1',
frequency : 50,
self.i2c = new i2c(self.address, {device: self.device}),
// Basic sleep function
self.sleep = function(ms) {
var waitTill = new Date(new Date().getTime() + ms);
while(waitTill > new Date()){}
return true;
// Initializer, needs to be run after changing frequency
self.initialize = function() {
// Calculate the prescaler based on frequency
let prescaler = Math.round(25000000 / (4096 * self.frequency)) -1;
// Set all PWM to 0
self.setAllPWM(0);
// Set all outputs to use a totem pole structure.
self.i2c.writeBytes(0x01, [0x04], function() {}); // MODE2 -> OUTDRV
// Set it to respond on call on all i2c busses and sleep (Oscillator off)
self.i2c.writeBytes(0x00, [0x11], function() {}); // MODE1 -> ALLCALL, SLEEP
// Sleep 50µS so the oscillator can calm down
self.sleep(1);
// Set the prescale to precalculated scale
self.i2c.writeBytes(0xFE, [prescaler], function() {}); // PRE_SCALE -> pre-calculated
// Disable sleep so it can start up the oscillator again
self.i2c.writeBytes(0x00, [0x01], function() {}); // MODE1 -> ALLCALL
// Spee 50µs so the oscillator can start up
self.sleep(1);
return true;
self.turnOffPWM = function() {
self.i2c.writeBytes(0xFD, [0x10], function() {})
// Usage: setPWM(channel, microsecounds);
self.setPWM = function(no, us) {
let steps = self.usToSteps(us);
// 0x06 -> 0x09 (LED0_ON_L,LED0_ON_H,LED0_OFF_L,LED0_OFF_H)
// The 4*NO changes it so it inclines depending on NO up to 15.
// Steps are maxmimum between 0 and 4096
// no is between 0 and 15
if(steps < 0 || steps > 4096) { return false; }
if(no < 0 || no > 15) { return false; }
// Lets write the start high to step 0
self.i2c.writeBytes(0x06+4*no, [0x00], function() {})
self.i2c.writeBytes(0x07+4*no, [0x00], function() {})
// Then write the end high to steps calculated from usToSteps
self.i2c.writeBytes(0x08+4*no, [steps & 0xFF], function() {})
self.i2c.writeBytes(0x09+4*no, [steps>>8], function() {})
// Usage: setPWM(microsecounds);
self.setAllPWM = function(us) {
// 0xFA -> 0xFD (ALL_LED_ON_L,ALL_LED_ON_H,ALL_LED_OFF_L,ALL_LED_OFF_H)
var startSteps = 3071;
steps += startSteps;
self.i2c.writeBytes(0xFA, [startSteps & 0xFF], function() {})
self.i2c.writeBytes(0xFB, [startSteps>>8], function() {})
self.i2c.writeBytes(0xFC, [steps & 0xFF], function() {})
self.i2c.writeBytes(0xFD, [steps>>8], function() {})
// Calculate how many steps an specific µS can be
self.usToSteps = function(us) {
// E.g. 50hz cycle = 1000000µS / 50hz = 20 000µS pr cycle.
let MicrosecoundPerCycle = 1000000 / self.frequency;
// Then get how many µS we get pr step by dividing steps on µS pr cycle
let stepsPerMicrosecound = 4096 / MicrosecoundPerCycle;
// Then return µS wanted times steps we get per µS
return Math.round(us * stepsPerMicrosecound)
return self;
module.exports = PCA9685();
