Will a 85mm width battery fit?
Wondering if a battery that is 11mm wider than the usual battery will fit in a blue boat
Hi @NE_Ocean_Systems -
You could check with the 3D model of the BlueBoat, found it he technical details section on the product page! Generally, as long as it fits through the hatch, it should fit in the BlueBoat. Do you have a link to the specific battery you’re considering?
That 6s battery will mean you need to reduce your max motor throttle set-point, to avoid damaging the M200 motors. Typically 1800 / 1200 is sufficient for max / min, setup on the PWM outputs page.
² 6S input voltage is acceptable, but at reduced throttle level. Do not exceed 500W per motor.
With that said, it seems like it would fit!
