What is happening when sending PWM signal at zero to ESC
I’m using Raspberry Pi 3 to control a T100 Thruster via a BlueESC. When the thruster is spinning, I send a PWM signal at zero microsecond to the ESC and the thruster stops. To make the thruster spin again, it seems that I have to first re-initialize the ESC by sending a “stopped” signal at 1500 μs. Why is that?
Why is happening when I send a PWM signal at zero microsecond to the ESC? Why do I have to re-initialize the ESC before I can make the thruster spin again?
What’s the difference between sending a signal at 1500 μs and sending a signal at 0 μs?
@Yuanjie,
The BlueESC is really designed to work between 1000 us, full reverse, and 2000 us, full forward, with 1500 us being neutral.
Why are you attempting to send a 0 us PWM signal to the BlueESC?
A 0 us PWM signal may be an undefined value for the BlueESC controller?
Regards,
TCIII AVD
@Yuanjie,
Tom is right, sending 0 µs is an invalid command and will produce unusual results. The reason for that is that a 0 µs pulse is the same as no pulse at all. That means that the ESC will not receive any signal and after a short time it will require re-initialization to work.
The “stopped” signal for the BlueESC is 1500 µs.
Please let us know if that helps.
@Rusty
For how long the ESC has not received any signal will it require re-initialization to work?
Yuanjie,
I think it only takes 3-10 seconds before it deinitializes.
Thank you
