Hi all,
My current setup is a blueROV2 with the blueOS/Navigator retrofit and a waterlinked DVL A50. Additionally, we are converting the vehicle to an AUV, so I have installed a removeable tether that connects to a tp-link nano router as discussed in this link
https://www.ardusub.com/developers/wireless-topside.html
This setup is working for me. But I have one thing that is causing issues. It seems the Waterlinked DVL extension cannot find the DVL unless the tether is attached with the router turned on. In the case the tether is attached, it says that it is searching on [192.168.2., 192.168.3.] and finds it rather quickly. But, if the tether is not attached, then it tries searching on [192.168.3.*] and returns the possible DVL’s as .
My current workaround is to start the vehicle with tether attached, wait until it is found, then detach the tether and run tests. This tends to work for around 1-2 hours then the DVL disconnects from the extension and I’m in the same boat of having to restart with tether attached again
Any thoughts on how to get around this?
