The Ping 1D connected to my BR2 has stopped working.
The UART converter is a detected device
The Ping 1D works when connected directly to the laptops USB port.
On the Companion Web Interface Routing page, should it be listed as an endpoint or route? If it is supposed to be listed, how would I manually create the route?
That’s not how it works for the Ping1D, it has it’s own proxy/driver program.
In the companion web interface, you should see something like this if everything is working correctly. (note the echosounder must be connected before boot).
