Using LT & RT axis for tilt in Cockpit
As Cockpit recognises LT & RT axis on the X-box controller. Is there a way to use these as axis for controllable tilt/pitch, as opposed to using them as a tilt/pitch set point?
Hi @3dMB,
That’s not currently feasible, but should be once this change has been implemented.
There’s an underlying requirement for that which is in our current quarter goals, but the full feature may not get implemented until later in the year.
That said, once that requirement is implemented it should technically be possible to set up through a workaround, if you’re willing to not use the built-in MANUAL_CONTROL pipeline, and instead implement joystick outputs entirely through data-lake variables and one or more custom Actions.
you lost me on the third paragraph….ill take it as a ‘not yet’ :+1:
