Hello, All. I would like to use BLHeli, rather than TGY / SimonK, with the BlueESC hardware. When using TGY, a hardware-specific “include” file is used to define the functionality of the Atmega8 pins, and MOSFET layout, as used in BlueESC.
BLHeli functions much the same way - different variants of the firmware are assembled using “include” files for different ESC designs. Unfortunately, BlueESC is not on the list of supported designs. Before attempting to write an “include” file for using BLHeli BlueESC , I’d like to ask the following questions:
- Does an include file exist to use BLHeli with the BlueESC hardware design?
- If not, is BlueESC a clean-sheet design, or is it based on another ESC?
