We have a fathom-x top side board that appears to have an issue with the usb connection. We suspect, amongst other things, the board with PCB label FXTI-ELEC-USB-PCB-R1 – mostly because when we “wiggle” the usb cable (and we’ve tried multiple cables and laptops) we can sometime produce a communications disconnect. I’m looking at making a replacement board here as there is some urgency, but I can’t seem to find out any information about the connector that is in the middle of the board that powers the usb-ethernet converter. Does any one know of the connector type?
The unit is in the field at the moment so I can’t take a physical measurement as well – I’m hoping ot make a board up and delivery it to the field team ASAP.
